cosworth conrod weights
Old Nov 6, 2007 | 11:01 PM
lee2cossies's Avatar
lee2cossies
Default cosworth conrod weights
How close do the weights of each conrod have to be on a 2wd cosworth engine? Iv had everything else balanced but am doin the rods myself.One is 0.713 kg,the other 3 are 0.728kg.how close do they have to be?
Old Nov 6, 2007 | 11:07 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
on normal old road engines, usually within about 5 grams, ut i'd hope they'd be within 1g on a cossie. you probably have 'H' etched into the end of the three rods and possibly 'S' on the other one? probably had one replaced at some point in its life by someone who dosen't know what they're doing.
Old Nov 6, 2007 | 11:25 PM
scruffythefirst's Avatar
scruffythefirst
I thought they had to be balanced end to end?
Old Nov 7, 2007 | 12:48 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yep. definately sounds like a stray S or L one in a set of H's
Old Nov 7, 2007 | 12:05 PM
lee2cossies
Ah right, so either balance the odd one to match the rest or get a matching set? it looks the same,has the same part numbers just machined slightly different.Im building the engine to around 400hp so i want it right.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
