10 sec 1/4 mile
Originally Posted by Remko GT
I bet the white sapph (Rod Tarry's car?) that did 208mph can do it? That's a 2WD right?
Steve.
Originally Posted by MalteseFalcon
In a mk1 escort with cossi engine will run even 8s. In malta mk1 with Pinto and Nos run 9.7 all the time but in a Sapphire it's a whole different story!
The trouble with 2wd cossie's in grip, as the cars squat leaving the line, the wheels due to suspension arm pivot points suddenly have massive camber as a result of the squat and this leads to a massive reduction in grip. One lad, Danny? of some fabrication company, changed his rear suspension completely and was running 12's on just a stg3 set up.
Originally Posted by Yura
Did anyone know what is the time of 1/4 mile of st3 2wd cossie(330-350bhp) with road tires?
Thank you!
Thank you!
I`ve done a 13.5 but that was at crail which is basically like a gravel pit
The guy who had my Saff before me did a 13 dead@ Santa Pod@ 118mph, that's with a Zoo Adjustable rear beam fitted, plus he's a crap launcher..
Thing is, people forget, anything in the high 12`s is bloody good going..
Mine is 370bhp on road tyres i have done 12.91 @ 114.7mph, thats with normal suspension, as well and me being a tart off the line with a 2.3sec 60ft
Steve.
It recorded a 11.5 @ 139 the terminal saying it had lots of Power but no grip off the line, its much quicker now & expect a close to 150 terminal not really into quarter miles, but im sure a 10 is possible.
Rod
Steve.
Thats what mine was too
But your Saph has a bit more power than 330-350bhp
Steve.
And yours is 4WD NUMPTY.....
Steve, i worry about you sometimes
You'd be half way down the strip before i'd have traction...
Steve, i've only just looked at your sig, i always thought yours was an XR4*4
I'll give myself one of these..
F*ck sake pete now i need to give my self one
The quarter mile mostly depends on the first 60ft. So if you leave the line with more than 2 sec then you won't probably make much of a good time. The mk1 escorts pwered pintos make good times coz they got a first 60 of a 1.4!!!! So that saves a lot when comes to quarter mile figures. The 2wd sierras make 2sec best so it more time lose there. The 4wd s can have a 1.6- 1.7 and that saves almost aonother sec at the end. I only did 13.4 with a first 60ft of 2.8!!! and terminal speed of 109mph. Thats with road tyres and 15inch wheels with a 350bhp engine. Now I want to try with my new engine which is soppose to be more than 400bhp ond I got 17 inch wheels. Hope to be in 12s!!
