SOLD L8 SOLD
Parts for sale I dont need or want
3 bar MAP sensor £35
2wd TPS PF01 £20?
pair of Std TCAs for a 2wd sapphire
XS POWER alloy rad £180NEW never fitted
T34 .48, run at Stg 3 for a couple of hundred miles only- slight play in shaft, £350
Stage 3 set up consisting- 4x4 L8ECU with closed loop and wasted spark driver with MSD 330bhp EVO chip, £SOLD
Set of 4x Bosch 803 injectors £100
twin ignition amps and bracket with sub loom also£120?
Zetec coil to run £35
2wd TPS PF01 £20?
2wd TPS PF01 £20?
[size=6][b]Stage 3 set up consisting- 4x4 L8ECU with closed loop and wasted spark driver with MSD 330bhp EVO chip, £450
2wd TPS PF01 £20?
Thanks
Mart.
155lee
Oct 24, 2015 11:11 AM
