aeroquip fitting qustions + who is cheapest?
Old Nov 2, 2007 | 09:18 PM
xrsi's Avatar
xrsi
Default aeroquip fitting qustions + who is cheapest?
right i am currently in the process of establishing exactly what fittings i need to do my oil, fuel and brake lines in aeroquip's finest (read as bloody expensive) fittings and hose....
i have a couple of questions tho before i go and order them as they will prob be shipped from america to save a few £
The alu brake fittings, do they come in the blue and red anodised coating or are they just plain alu as i have the goodridge catalogue sat in front of me and the only fitting that mentiones the anodised coloured finish is the straight dash 3 one on the 600 PTFE lined hose.
Also the rocker cover i am using will be an RS1600i motorsport item, would i need an alloy or a zinc plated carbon steel weld on boss to weld to this rocker cover?
also who is cheapest for the fittings in the uk so i can see if there would be a saving if i were to get it sent over from the us?
any help would be great
thanks
James
Old Nov 2, 2007 | 10:19 PM
jon@work's Avatar
jon@work
try :
http://www.lister.co.uk/ecommerce/re...act=FRAMESETUP
or download the catalogue from :
http://www.thinkauto.com/
for the rocker cover, you'll need an alloy weld-on boss
Oct 9, 2015 07:38 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
TrevCos
Modellers Corner.
Aug 14, 2015 12:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
