200 Block info needed,not a repost.was deleted
Old Nov 1, 2007 | 08:29 PM
rscostalot's Avatar
rscostalot
Default 200 Block info needed,not a repost.was deleted
Sorry was deleted,
Info needed,as i nothing about it as ive never come across one b4..
1 Is it a 200 motorsport block??..have been told it is...
2 oil jurnels blocked off
3 has been long studded x 6
4 bores are standard size
5 has been machined at top of bores to take fitting kit which are 4.5mm in width....1-1.5mm in depth not to sure...
6 No lip on bores and has end caps...with bearings still fitted...
it looks rusty but has been in a garage and is mostly dirt/grime
Better pics can be sent if you need them....
cheers
Old Nov 1, 2007 | 08:32 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
machined for a coopers ring gasket
cos elle
Sep 1, 2015 06:48 PM
THE RADMAN
Aug 17, 2015 06:48 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
THE RADMAN
Jul 30, 2015 09:50 PM
