denso iridium plugs who runs there cars on them ??
http://www.densoiridium.com/
Ultra Fine Electrode
By harnessing the power of Iridium, DENSO is suddenly able to shrink the surface area of the center electrode - the critical component of a spark plug. Unlike a typical platinum plug that has a 1.1mm diameter center electrode, DENSO Iridium Power plugs have the world's smallest center electrode measuring 0.4mm in diameter. This means that the voltage requirements are decreased while firing performance is greatly improved.
is that the full part number for em
i got k20txr's in my bmw, prob the most comon plug ever sold
its the same as a bosch besp+7
always wondered what densos people use as i got fucking hundreds of em at work as we supply lots of companys with em, such as fensport is one of our smaller customers
reason why i asked was a crushed spark
never heard of that
http://www.densoiridium.com/patented...y.php#u-groove
the rest of the of the FAQ...
http://www.densoiridium.com/faq.php
intresting read
intresting read
saff is working!!!...atm
i had denso's,..........one melted and the tip fell off.end off engine........now using NGK's...........(not saying it was the plugs fault....but if ur engine isn't running spot on,then u shouldn't use iridium's)
Zoggon
Aug 10, 2015 10:39 AM
