removed egr now a problem.
i removed the egr from my old fiesta si whilst i was doin a head gasket on it, now eventualy after geting round to doing it it wont start? theres plenty o spark and winds over very quick as before, will i need to put it back on? or can i by pass it sum how? any help wud be grately apreciated
on my old 1992 xr3i i tried disconnecting the egr on it and it wouldnt start and i even tried running the engine and disconevcting the multi plug and it would just die but i am sure there must be a way of getting around it. i did it on my rs 2000 with no probs
is there any leaks on the inlet side of things though, even if the exhaust manifold wasnt blanked off i would expect it to run but obviously it would sound like a bag of nails!
No engine requires EGR to run there must be something else at fault
it wont be the egr valve. you will have knocked or disconnected something while doing the egr. check all the connections, pipes etc around where you were working.
oh.... and learn to spell!!
Orion_Gav
Sep 29, 2015 04:50 PM
