Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Street KA uprated Brakes Need Help
Old Oct 29, 2007 | 11:29 AM
dougyt26's Avatar
dougyt26
Default Street KA uprated Brakes Need Help
Right im looking to up rate the brakes to a 280mm disks but would love 300mm from a mondeo st if im right was on pumaspeed web site witch do the conversions but was wondering if i could probably save money that i don't have and source the parts my self was just wondering if any one could give me some guidance on exactly what parts i mite need am i right in thinking that i will need 3mm spacer for the disks and possibly a bracket to hold the caliper higher up?
here is the site that dose the up rated conversions but it dose not really give a way what calipers they are using 300mm Brake Upgrade
Easy DIY fitment
Low maintenance
Unbeatable price
NOW WITH MINTEX XTREME PADS AS STD !
Drilled and grooved disc available also
Full 300mm brake kit .The Kit consists of -
New plain discs , new Mintex Xtreme pads and a replacement direct bolt on Full Replacement larger Caliper
( will need to drill 4 x 10.6mm hole to 12mm to enable to fit)
Fantastic stopping power at bargain Price
This standard base kit uses a recon or used caliper. choice of colour Gold, Red, Blue,Silver
http://pumaspeed.co.uk/catagory.php?catid=20&subid=41
Old Oct 31, 2007 | 01:38 AM
wide ka's Avatar
wide ka
you need mondeo v6 calipers, and focus st170 disks, drill a 12mm hole in hub and bolt up, thats about it
Old Nov 20, 2007 | 09:33 PM
zippyka80's Avatar
zippyka80
Default cossie 4 pots and st170 front discs
i used cossie 2 wd 4 pots with a adaper plate from this guy
http://cgi.ebay.co.uk/Ford-RS-Turbo-...QQcmdZViewItem
then you can bolt on 300mm st170 front discs but you need 17" rim to clear then use braided hoses
cost bout £400
Old Nov 25, 2007 | 08:34 AM
wide ka's Avatar
wide ka
you dont need 17" wheels for 3oomm brakes i had 15" with the st disks and v6 calipers
Old Dec 17, 2007 | 09:47 AM
JamesR1's Avatar
JamesR1
Anybody for a brew?
Yeah They do fit under 15" just, Youngdan has the same set up iirc
Old Jan 4, 2008 | 09:01 PM
zippyka80's Avatar
zippyka80
fair enough pple my bad
Old Jan 17, 2008 | 08:07 AM
Dal_'s Avatar
Dal_
Depending on the wheel, you may need to shave a bit off the calipers. Mate has Mondeo brakes under his 15" Puma props, and they just foul. Only a little tickle to get it clear though.
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
