HELP !!!
Old Oct 29, 2007 | 10:16 AM
pauldonachyrs's Avatar
pauldonachyrs
Default HELP !!!
Hi There Lads I Got In My Car This Morning And The Gear Box Was Tight As F*ck Wouldnt Go Into Gear So I Switched It Off Put Into Gear Then Started In Gear When It Started It Crept Forward Like There Is No Clutch Like It Was Dragging...
I Phoned Couple My Mates As They Are Mechanics They Both Think It Could Either Be Slave Cylinder Or Clutch They Even Said If It One Not The Other Be Better Doing Both While The Box Is Out ...
If You Have Any Other Suggestions Wot It Can Be Please Let Is Know.... Cheers
P.s If It Is Clutch And Slave Where The Cheapest And Best Place To Get Them Both From
Old Nov 23, 2007 | 08:27 PM
phill295's Avatar
phill295
does the gearbox work ok when your foot is off the clutch ?
