Escort RS1600i This forum is for all things about the Escort RS1600i
1600i metering unit
Old Oct 26, 2007 | 12:52 PM
S1Luke's Avatar
S1Luke
Default 1600i metering unit
is the metering unit from series1 the same as 1600i
if so whats the diff
thanks people
Old Oct 27, 2007 | 11:53 PM
jimrs16i's Avatar
jimrs16i
not at all the same..
Old Oct 28, 2007 | 11:56 AM
S1Luke's Avatar
S1Luke
Default m/unit
so will need the unit of rs turbo then. for turbo conversion
Old Oct 30, 2007 | 09:30 PM
XR2's Avatar
XR2
Default Re: m/unit
When you use the whole ERST KE-Jet then yes.
There are many turbo'd XR3i/RSi that use the standard metering unit...
gingeRS
17
Oct 2, 2015 09:42 AM
Steve Escos
Oct 1, 2015 06:57 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
