removing old bushes?
Old Oct 25, 2007 | 05:00 PM
w1zord's Avatar
w1zord
Default removing old bushes?
help!
im tryin to remove the bushes out of my bottom arm! i've beaten the crap out em all day today... and there still in!
Anyone know anyway of getting em out? there standard bushes, i got poly bushes to go back in.....
Old Oct 25, 2007 | 05:41 PM
garyrs's Avatar
garyrs
are you talkin inner or outer tca bushes , saph ??
Old Oct 25, 2007 | 06:06 PM
w1zord's Avatar
w1zord
yeah 2wd saph.. its the rear arms im having trouble with! both sets of bushes...
its done my nut in all day..
Old Oct 25, 2007 | 07:00 PM
garyrs's Avatar
garyrs
if there what im thinking off its a round bush with a metal cylinder in the middle , i havent removed that bush yet , but my style is to just drill the shit out of the bush its self untill it becomes loose enough to bang throu
Old Oct 25, 2007 | 09:15 PM
Rashers's Avatar
Rashers
Default Bushes
Mate you will be fucking lucky to bang these out i had my arms off the car using a big vice and a couple of sockets either side still could not budge them had to have them pressed out in the end ,if there still on the car you could try using some threaded rod a couple of nuts a socket that will pull the bush through Good luck
Old Oct 25, 2007 | 10:26 PM
Moonstone Mart's Avatar
Moonstone Mart
I removed the trailing arm bushes at work. Heated them up with the gas bottles and then pressed them out with the press. Even with this they were very tight coming out!
Mart
Old Oct 26, 2007 | 08:44 AM
silky16v's Avatar
silky16v
Get on That!
Burn them
Old Oct 26, 2007 | 03:19 PM
Moonstone Mart
Originally Posted by silky16v
Burn them
Burning wont really help, they need heating up.
The bushes are a metal tube with a rose joint inside so the tube/bush needs pressing out.
Mart
Old Oct 26, 2007 | 03:21 PM
w1zord's Avatar
w1zord
right... so today, i brought out the big guns... i've tried burning em! (that was fun!!lol) smashing fuck out em, and then tried drilling em!
and the little fuckers still havent moved.
going to the local engineers mon, see if i can get em pressed out.
cheers for the replys guys..
Orion_Gav
Sep 29, 2015 04:50 PM
DavidK
Sep 27, 2015 02:55 PM
