failed MOT emissions. ..ford escort LX 1.6 1998
Old Oct 25, 2007 | 12:45 PM
starfish's Avatar
starfish
Default failed MOT emissions. ..ford escort LX 1.6 1998
only 51.000 miles on the clock
good engine state..but failed MOT
what to do..
also noticed using too muc fuel
any suggestions
Old Oct 25, 2007 | 01:31 PM
Smoker's Avatar
Smoker
Default mot failure
check lamda probe and your egr valve!
Old Oct 25, 2007 | 02:04 PM
Yeh i was gonna say lambda sensor. Theres no holes in the exhaust anywhere is there.
Old Oct 25, 2007 | 09:59 PM
lukemakepeace's Avatar
lukemakepeace
the cat could also be at fault but this wouldnt cause the fuel problem.
Old Oct 26, 2007 | 06:40 AM
Could also be water temp sensor at fault.
Old Oct 26, 2007 | 10:15 AM
Aaroncast's Avatar
Aaroncast
-WHAT DID IT FAIL ON??????????????????????????????????????????
Old Oct 26, 2007 | 12:09 PM
antony215's Avatar
antony215
Escort Rs Turbo
Think the clue is in the post title
Old Oct 28, 2007 | 09:17 PM
gtit's Avatar
gtit
comon prob is breather pipe, between oil breather on the front of the block 2 the inlet manifold, it wars on other pipes and just generaly gets fuked with age, my mates a fordy mechanic, was just a suggestion as its cheaper to try tht first rather than a lambda which it also cud be, n if the pipes fuked runs crap 2
Old Dec 1, 2007 | 03:02 PM
mappindude's Avatar
mappindude
what part of the emissions test did it fail on?
co? hc? lamda?
Old Dec 1, 2007 | 09:05 PM
phil_focus's Avatar
phil_focus
or even did it fail on a high idle????
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
ginger1979
Jul 31, 2015 09:56 PM
