help asap
Old Oct 24, 2007 | 04:07 PM
dkmk4's Avatar
dkmk4
Default help asap
im only showing harf rev on the revcounter iv wired them up and only showing 500 revs and wont go past 3,000 help asap car in bits
Old Oct 24, 2007 | 05:13 PM
What car is it.
Old Oct 24, 2007 | 05:55 PM
dkmk4's Avatar
dkmk4
mk4 escort 1.3 hsc engine clocks are out to an s2
Old Oct 24, 2007 | 05:58 PM
lukemakepeace's Avatar
lukemakepeace
do they not just plug into mk4s fine? without the need of wiring all over the place? and where did you wire it too? coil or ECU?
Old Oct 24, 2007 | 06:03 PM
dkmk4's Avatar
dkmk4
yer they plug in ok when i wired the clocks up i used a set wich was wired with a coil pack they worked fine i bort a set with plazma kit on them wich was out of a s2 turbo wich has a coil and im trying to wire them up to a coil pack
Old Oct 26, 2007 | 03:02 PM
dkmk4's Avatar
dkmk4
any 1 know how?
Flatlinedan
Sep 18, 2015 12:41 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
syathome2000
Jul 27, 2004 01:32 PM
Fudgey
Jul 21, 2004 10:11 PM
