idle climbs as I slow down
Old Oct 21, 2007 | 04:00 PM
james.dylan83's Avatar
james.dylan83
Default idle climbs as I slow down
A challenge fellow focus heads. My 1800 zetec has been idling badly, now 90% sorted thanks to cleaning out the iscv, but theres a hose which has become soft and collapses when the engines running and this seems to effect the idle?? Anone out there had this problem before or know what the hose is called/does.
The hose comes out of the back of the throttle body and then runs under the coil pack into a plastic pipe which seems to go into the engine block?
The question has been asked before as to what this is but no answer posted.
thanks to anyone who can help
Old Oct 21, 2007 | 06:00 PM
truthordare's Avatar
truthordare
Omnomnomnom
Hiya mate, it sounds like your breather pipe thats been corroded by oil causing it to collapse, this happens quite regularly and does affect the idle. If you replace the breather, it should run sound.
Debs
tankybaby66
Feb 6, 2016 02:24 PM
Chas
Oct 5, 2015 07:13 PM
fordrallycar
Sep 30, 2015 07:57 PM
RSmark84
Sep 13, 2015 01:29 PM
