View Poll Results: doo you need to get your crank re cut wen replacing botem end shells
yes !!!!
0%
no !!!!
100.00%
Voters: 2. You may not vote on this poll
escort rs turbo bottem end shells info can you help ???
Old Oct 15, 2007 | 09:22 PM
bobe-f's Avatar
bobe-f
Default escort rs turbo bottem end shells info can you help ???
i have been bulding a s2 escort rs turbo for over a year now 2 floorpans 2 new iner and outer sills 2 wings scuttel panel and hole new frunt and im fineshed with the welding now lol the car got driven to my hows with mot over a year ago and got striped im now on to rebulding the engen and iv never been sure wether or not to replace bottem end shells ? thers a tiney amont of play int 1 of them ? i was told i would need to get my carnk re cut is this true ? and if so will i have to get difrent shells ?
robert edinburah
Old Oct 16, 2007 | 12:19 AM
rs_cabby's Avatar
rs_cabby
the crank wont need re-grinding unless it is damaged/worn.
if for some reason you did need to get this done then the
company carrying out the work should specify what oversized
shells you need.
Old Oct 16, 2007 | 07:51 PM
bobe-f's Avatar
bobe-f
thanks dont think it will need re-grinding onley at 52 thousand miels going to replace them now while its striped rather than wen it starts to go
thanks for the help
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
