2wd with l8 ecu
Old Oct 15, 2007 | 06:52 PM
wimble's Avatar
wimble
Default 2wd with l8 ecu
ive just put a L8 ecu in my 2wd saph and the amel valve clicks constently when you touch the throttle
and the idle speed valve dosent work
i have chaned the tps to a pf09
do i need to swap the two outside wires around on the tps
i was told you dont need to if using a pf09
Old Oct 15, 2007 | 07:35 PM
jon@work's Avatar
jon@work
when fitting a L8 ECU onto a 2wd loom, you need both the PF09 and to swap the 2 outer TPS wires
Old Oct 15, 2007 | 07:50 PM
wimble's Avatar
wimble
thanks mate i will do it arfter work
Old Oct 17, 2007 | 07:52 PM
wimble's Avatar
wimble
i swaped the two outside wires on the tps
the car runs smoother
but the idle speed valve and the amel valve dosnt work
Old Oct 17, 2007 | 09:43 PM
jon@work's Avatar
jon@work
check they've both got a 12V feed to them (they're earthed through the ECU) - if not, check fuse/wiring
Old Oct 18, 2007 | 10:22 AM
DazC's Avatar
DazC
Both usually fed from the fuel pump fuse on black with red trace wires.
mark r
Sep 29, 2015 07:27 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
