WHICH AIR FILTER SHOULD I USE ?????
Old Oct 13, 2007 | 04:35 PM
pauldonachyrs's Avatar
pauldonachyrs
Default WHICH AIR FILTER SHOULD I USE ?????
HI THERE AGAIN WHICH FILTER SHOULD I USE A K&N GENII OR A K&N PANEL FILTER THE CARS IS STANDARD JUST NOW PUT I AM GOING TO DO A FEW SENSIBLE ASWELL LIKE DE CAT,MONGOOSE SYSTEM,BLUE FIN OR DREAM SCIENCE {DONT KNOW YET} RECIRCULATING DUMP VALVE AND A PRO ALLOY CHARGE COOLER.. SO WHICH ONE YOU THINK I SHOULD USE....
Old Oct 15, 2007 | 04:57 PM
pauldonachyrs
Default frs
help!!
Old Oct 15, 2007 | 05:59 PM
testastretta999's Avatar
testastretta999
Default Focus RS
Pro Alloy charge cooler well made and good performer.
Air filter wise I would stick with std unless you find dyno graphs to prove any substantial gains.
Dream science prob better than bf for several reasons.
Decent resale value
Multiple maps
Cheaper to reset
Forge recuic valve
Old Oct 15, 2007 | 09:01 PM
pauldonachyrs
Default frs
thanks buddy so do you think the forge 007p is better than the bailey then
Old Oct 16, 2007 | 03:39 PM
testastretta999
Default Dv
I would not say either dv has an advantage over the other. You will be able to find more info on setup with Forge one as there has just been a group buy for FRS.
Old Oct 16, 2007 | 09:46 PM
pauldonachyrs
Old Oct 18, 2007 | 03:08 PM
LloydyRS's Avatar
LloydyRS
I have recently taken my K&N GenII off of the car and then put it back on the car as I missed the noise
Gains about 4 bhp extra but loses a bit of torque I think. Either way I am not fussed about performance.
With the K&N GenII you will hear the recirc dump valve a lot clearer and it does turn heads. Never had a problem with idling etc.
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
mondeomark
Sep 28, 2015 06:28 AM
