flat rs1800
ive just got myself a cheap rs1800 run around the problem im having with it seems a bit flat going from first to to third gear as if its going no where after 4.5k it seems to pick up can anyone give any info in what it could be proper doing my head in
cheers bri
cheers bri
Originally Posted by Wardy257
To test the MAF just unplug it. If it gets better clean the inside of the MAF!!
Igniton problem could be anything. Get your mulitmeter out and check the leads, coil pack etc.
