Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
exhaust hangers, rear hub nuts
Old Oct 11, 2007 | 09:24 PM
Mr C's Avatar
Mr C
Default exhaust hangers, rear hub nuts
As above; I need all 3x exhaust mounts that bolt to the underside of the shell on a sapphire so I can hang my exhaust to the floor via rubbers
Also the rear 42mm hub nuts
turbo water cooler rad
power steering cooler pipe, OE Ford attempt will do
more parts that I cant think of right now
A pair of Seat mount spacers, preferably alloy and 65mm tall total W.H.Y.?
Old Oct 11, 2007 | 09:31 PM
LukeT's Avatar
LukeT
How many of those bits are the same as an XR4x4 hatch? Fucked if I can get them undone but ya can have the hub nuts - are the exhaust hangers the same? Maybe the steering pipe too.
Old Oct 11, 2007 | 10:52 PM
xr4x4rs's Avatar
xr4x4rs
steering pipes are different
hubs nuts are the same
only 2 exhaust mounts bolt underneath
1 on gearbox and the other on rear beam, the other one on the rear beam is fixed on and the back box is fixed aswell
imnot too sure on the gearbox one ona 2wd though
Old Oct 12, 2007 | 08:23 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Nuts and washers are still available from Ford for under a tenner fella
Old Oct 13, 2007 | 07:54 PM
Mr C's Avatar
Mr C
cheers, will get them ordered new then
I would think all sierra mountings were the same on the shell yes. I need the two on each side of the centre box and I dont have anything at all on the shell for the back box so would imagine the mount was originally welded on??
Whatever you have wuld be helpful thanks.
atm
Sep 1, 2015 04:56 PM
Ridgey
Aug 30, 2015 08:37 AM
cameron2
Aug 19, 2015 11:49 AM
track.focus'd
Aug 12, 2015 05:53 PM
cameron2
Aug 10, 2015 12:14 PM
