help ive snapped my cam belt need advice
i was driveing my s2 erst last night when the cam belt snapped i dumped the clutch straight away but ive been told to check the valves how do i do this ? and what other damage could be done need urgent help please
check the valves buy either a leak down test or whip the cylinder head off.....TBH mate its likely to have done some internal damage to the engine if the belts snapped so best to whip the head off and see how much damage.....hopefuly its onyl a few bent valves and a couple of hundred to fix.
Dan
Dan
i bet it was in first pulling away woth foot down!
dumping the clutch dosent do anything to help really.
the pistons would have bent the valves and in worse case the valves could have destroyed the pistons. you need to take the head off, change all the broken/bent valves, and mabye the pistons but check if the pistons are okay first.
then youll need to have the head skimmed before you put it all back together with a new head gasket.
then time the engine and thats all.
Originally Posted by antony215
Guaranteed that you have bent valves as the cvh is prone for it if the belt snaps
How fast were you going when it went??
i might just break it would it be worth more than 500 in parts do you think it pritty clean inside and out or is it worth repairing it
Repair isnt as costly if you do the work yourself
you would bend the valves if the car was just sat idling let alone driving.
CVh's are a piece of piss to work on just rip the head off and lap some valves in. If you're really on a budget you could go down the scrapper and whip some valves out, but new would be the best option.
Head off, new valves, head bolts and gaskets, head back on. Easy.
Gasket set is about £40 and valves are about £4 ish each. Cambelt is about £15 from Ford.
You can have it done in an afternoon.
If you're a beginner at this stuff, it will take longer so don't rush and ask for as much advice as you can. If you're unsure about swapping valves over, ask your local engine machineist to do it for you (and fit new valve stem oil seals).
CrOwSoN15
Sep 14, 2015 11:33 AM
grishenko45
Sep 9, 2015 12:58 PM
