ABS REMOVAL
Old Oct 9, 2007 | 05:27 PM
cozziepj's Avatar
cozziepj
Default ABS REMOVAL
hi can anyone tell me what you need to do to remove the abs block on the cossie and put the brake pipes straight to each wheel, rather than thru the abs block???
cheers
Old Oct 9, 2007 | 05:49 PM
I think you are going to need to just to replumb it that's all, but abs also stops full pressure reaching the brakes that the pump can deliver so best to remove this as well and put on a new m/cyl ?
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
