Idle screw
Old Oct 4, 2007 | 12:42 PM
Bubby's Avatar
Bubby
Default Idle screw
Where is it?! coswroth 1993 dohc blue top turbo engine - can't locate the idle screw to turn idle down. Currently running at about 10000-11000 rpm.
Presumably its fairly straightforward...?
Old Oct 4, 2007 | 01:35 PM
gingeRS's Avatar
gingeRS
if its the same as the 1992 sapphire cosworth
its underneath where the boost hose from the intercooler joins the throttle
i use a stubby flat blade screw driver to adjust mine.
Old Oct 4, 2007 | 02:55 PM
10,000 - 11,000 RPM, that is some high tickover, I see why it needs turning down!!
Old Oct 4, 2007 | 05:05 PM
mrjenrst's Avatar
mrjenrst
Old Oct 6, 2007 | 02:23 PM
2001ode's Avatar
2001ode
Hi,
That's for you.
Regards.
Claude
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
hopper350
Sep 4, 2015 12:53 AM
