saff exterior door handles
Old Oct 3, 2007 | 07:22 PM
slowpoke's Avatar
slowpoke
Default saff exterior door handles
does anyone know if and how they come apart ?
noticed on the back there seems to be like a grub screw holding things together but not sure if you can un do it
anyone know ?
Matt
Old Oct 3, 2007 | 07:31 PM
If I remember right there is a screw each side inside the door, to hold handle on.
Old Oct 3, 2007 | 07:33 PM
The DIVA's Avatar
The DIVA
Matt....
You have to take the door panel off,remove the lock mechanism protective cover(one screw in the edge of the door and one in the inside of the door),then remove the rod from the handle to the lock assy(they unclip)then unscrew the 2 self tappers that go through the doorskin into the back of the handle and........Voila.....it should come off...
Old Oct 3, 2007 | 07:37 PM
slowpoke's Avatar
slowpoke
ok i should of made it more clear lol
i have already got the 4 handles from a scrapper so they are sat here on my desk
i want to take the actual handle bit off the part that screws into the door
Matt
155lee
Oct 24, 2015 11:11 AM
Vincereese
Sep 18, 2015 12:48 PM
Vincereese
Sep 18, 2015 12:47 PM
Mark V8
Sep 13, 2015 09:34 AM
hopper350
Sep 4, 2015 12:53 AM
