cossie cambelt
Old Oct 3, 2007 | 04:47 PM
bigcam's Avatar
bigcam
Default cossie cambelt
hello, just a bit ov advice guys, iv just got a 4wd cos and was going 2 change cambelt etc, do i need any special tools to do the job, im quite mechanically minded, or is it tricky and u think i should leave it up to the experts, many thanks shaun.
Old Oct 3, 2007 | 05:46 PM
Easy to do no special tools at all, just be best to do the tensioner at same time ?
Only hard bit is some 4wd pulleys are so bloody tight to get off, 2wd ones seem to literraly fall off.
Old Oct 3, 2007 | 07:52 PM
I had to remove my radiator so that i could put a pulley puller on to get it off cause mine was tight coming off.
Old Oct 3, 2007 | 09:54 PM
bigcam's Avatar
bigcam
thanks guys. il giv it a shot, yeh il do the tensioner aswel
Old Oct 4, 2007 | 02:12 PM
saph4be's Avatar
saph4be
make sure you turn tensioner the correct way of cam belt will rub on housing
gcfcos
59
Oct 6, 2015 05:04 PM
Chas
Oct 5, 2015 07:13 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
