under floor heating
anyone fit this? im thinking of using it in the wc before i put the floor tiles down,its only 1m square but just wondered how you go about the wiring and is it cheap enough to run?
Ive just laid this in our house. Works a treat! Dogs love it, keeps their little paws warm lol
Got a sparky round to wire it up as had the house rewired as well. Didnt look to difficult though. couple of wires coming off the floor mat going into back of thermostat, then wired to live.
Cant comment on costs as only had it about 6 weeks - not had a bill yet... i'll let you know though
well pleased with it though
Originally Posted by mad_on_Series_one
Originally Posted by gingeRS
socks or slippers, much cheaper
Have been thinking about this for a house we're buying, but getting it plumbed into the heating system rather then electric. Mebs a bit OTT for 1sqm, but seen this on the net, not sure if they are any good:
http://www.underfloorheatingdiy.co.uk/
if you have underfloor heating that i splumbed in it involves a bit more work. obviously the floor will need to be dug to take the plumbing. A mat you simply lay on the flor before you tile.lot less hassle.
cheaper too
Originally Posted by Graceland
Carbon footprint my arse - another cunting government bright idea to impose more tax on us
2 Ways,
1. Either use the proper electrical heating system and get it wired in on a theomostat, expense depends on how often its on and the wattage of the heating elements but you can have it come on automatically depending on the tempreture.
2. Do what ive seen more and more people doing now and thats running the system off the cetral heating system, small diamiter plasic pipe round the floor linked to the central heating system. Its cheap but its not indepent as with electrical elements because its linked to the radiators.
Originally Posted by St3V3_C
It's important to have good insulation under the heating element to make it efficient.
Carbon footprint - bollocks. He'll use less conventional heating for that room
put it in my conservatory late last year and only used it over winter. im now 600 in debit with british gas for my electric. but it is 14 sq m.
feels bloody good on your feet though.
well worth it.
regards
mike
well worth it.
regards
mike
find the nearest heater pipe
take it off of that with plastic pipe and fittings etc and run a small loop of it around the area you want to heat
when the heating turns on, so does this little bit of land
I'm a plumber and I have fitted underfloor heating on 4 occasions, all been big systems and the central heating instead of the electric but they were all in new builds.
I think they are great bits of kit, however I dont know how much it warms the room?? Although when testing it, it is nice awnd warm on your feet!
Orion_Gav
Sep 29, 2015 04:50 PM
cossie09
Sep 10, 2015 06:56 PM
