Cooling system noise
Old Oct 1, 2007 | 07:04 PM
Tom_FRST's Avatar
Tom_FRST
Default Cooling system noise
Hi guys, i have a 1990 fiesta rs turbo, when the engine is at normal running temp and is switched off there is a bubbling noise coming from the top hose and you can feel the coolant passing through it. I've carried out a headgasket check and it came back as all o.k, i have also pressure tested the cooling sytem and found no leaks.
Any ideas or suggestions would be much appreciated
Many thanks Tom
Old Oct 2, 2007 | 08:21 AM
7554roy's Avatar
7554roy
when my erst was doing this i tryed bleeding it countless times with no luck then someone said to me to change the thermostat and expansion tank cap and it worked on mine dont now if its the same on frst they said its getting air into the cooling system hope this is a help to you
Old Oct 2, 2007 | 11:33 AM
Tom_FRST's Avatar
Tom_FRST
nice one mate, ill get them replaced and let you know
many thanks in advance
Tom
Old Oct 2, 2007 | 12:17 PM
It is not getting air into the system but losing pressure, and this lowers the boiling point of the water, so it causes localised boiling, and the pipes go hard as it does.
Old Oct 2, 2007 | 12:55 PM
mick_rst's Avatar
mick_rst
Slap Head
sell it and buy a pulsar
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gingeRS
17
Oct 2, 2015 09:42 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
