ESC COS power steering tensioning pulley
Old Oct 1, 2007 | 04:16 PM
D2EVS's Avatar
D2EVS
Default ESC COS power steering tensioning pulley
mine has siezed now can i just replace with a similar pulley or do i get one for £80 odd plus vat from frauds
Old Oct 1, 2007 | 04:43 PM
D2EVS's Avatar
D2EVS
Default anyone?
Old Oct 1, 2007 | 04:46 PM
Disabled Account's Avatar
Disabled Account
You cannot buy the pulley on it's own, or replace it AFAIK.
It is factory pressed into the large cast iron mounting bracket. I think that is why it's so expensive.
Old Oct 1, 2007 | 04:47 PM
kjc300's Avatar
kjc300
fords about £90 got one not so long ago!!
you just missed a new one on ebay too!! Went for about £40!!
Old Oct 1, 2007 | 09:15 PM
The Youth.'s Avatar
The Youth.
they are a piece of piss to free off, my air con tensioner (which is just about the same) was siezed 4 years ago, loads of wd40 then moving it backwards and forwards in a vice followed by loads of "normal oil" soon had it freed off, still free now!!!
steve
Old Oct 1, 2007 | 09:41 PM
GUZZLER's Avatar
GUZZLER
i just fitted a new one to mine, my had lost a bit of tension, the belt had started making a noise like an old dry belt makes
Old Oct 1, 2007 | 11:19 PM
COS 22's Avatar
COS 22
just put a spare one on mine
i took the complete mounting bracket off which is a pain and there is a 17mm bolt holding the tensioner to the bracket
i had to take the rad out to get the alternator bolt out
Old Oct 2, 2007 | 06:50 AM
Mr RS500's Avatar
Mr RS500
No it isnt
it just bolts on from the back
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
