Fiesta Turbo problems
Old Oct 1, 2007 | 12:06 PM
Oranoco's Avatar
Oranoco
Default Fiesta Turbo problems
Had to happen, she's been pretty much good as gold since I got her and I said to a mate she'd never put a foot wrong. Last night things went wrong
Was in third gear at about 2500rpm and gave it a boot full and nothing happened, boost climbed but the revs didn't. Lifted off and put my foot down again and it went really well. Then I opened her up again and she pinked like mad. Then I tried again and she went quickly again. Decied to leave things alone and just nurse her home and on light throttle she jerks and hesitates and I'm getting lots of popping when decelerating.
I have a new fuel pump to go in but fear this isn't my problem
Spec is
T3
195 chip
701 injectors
CVH35 cam
Pace Interwarmer
Any help or suggestions as cash is tight right now so can't afford to pack her off to my mate Rob at SCC to be sorted
Old Oct 1, 2007 | 12:12 PM
Rob M666SCC's Avatar
Rob M666SCC
Check all the vac pipes on inlet manifold
Old Oct 1, 2007 | 12:33 PM
Luca's Avatar
Luca
Lukesville
Does sound like a vacum problem, check all the hoses are connected and sealed and follow all the vacum lines....
Are you running amal valve.
Old Oct 1, 2007 | 01:15 PM
Oranoco's Avatar
Oranoco
Had a quick look Rob mate but all looks fine on the vac pipe front
Amal valve has been removed. I'm only running about 11-12psi
Old Oct 1, 2007 | 02:59 PM
GavStyli's Avatar
GavStyli
Kasapis
i cant think of anything else but did u check the vacum hoses while the car is running? much easier
Old Oct 1, 2007 | 03:03 PM
GavStyli's Avatar
GavStyli
Kasapis
check the chip hasnt moved?
carlo
24
Oct 5, 2015 08:20 PM
druidgetafix
Aug 15, 2015 10:22 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
turbobill
Aug 1, 2015 08:55 PM
