Cosworth parts...
i am having a garage clear out, i have a cosworth 205 block, 2wd & 4x4 sump, 2wd engine arms, an Escort cosworth front diff, a set of mahle pistons std comp / size with valve pockets inc pins and rings, apexi avcr boost controller plates for the escort to fit in the center heater vent`s place, Escort front fog lamps, washer tank, 4x4 plenum cover powder coated in black and few other odds and end`s...
open to offers on all bits... pm me .....
Originally Posted by MK2 COSWORTH
what would you wabt forthe boost controler andthe rocker cover oh is it converted to take a breather system? kind regards
cheers
Dennis
Adam Graham
Sep 6, 2015 06:04 AM
