engine builders/tuners verniers?
Old Oct 3, 2004 | 10:17 PM
xr4x4rs's Avatar
xr4x4rs
Default engine builders/tuners verniers?
do these help, what benefits would i get from these pulleys against the standard pulleys
on cossie 4wd with bd16s
but basically just want to know if there worth spending this much money for little gains if any?
thanx ppl
Old Oct 3, 2004 | 10:19 PM
Daviet's Avatar
Daviet
also wondered this but for a S2 turbo.got one there just not sure what gains if any it will make
Old Oct 4, 2004 | 09:14 AM
GARETH T's Avatar
GARETH T
i say they are a must (or offset keys)
give you the ability to have your cam timing stop on and not too the nearest tooth!
a must
gareth
Old Oct 4, 2004 | 01:21 PM
xr4x4rs's Avatar
xr4x4rs
yes but what benefits do u actually get /i mean will i notice the difference in performance?
Old Oct 4, 2004 | 09:57 PM
GARETH T's Avatar
GARETH T
it does depend on how far out your cam timing is on standard pulleys if you'll notice a difference! If the head has ever been skimmed or other things!
if the cams have been changed for aftermarket jobbies then its silly not too run accurate cam timing! can make a massive different to lag and torque curve
Old Oct 4, 2004 | 10:02 PM
Daviet's Avatar
Daviet
cheers mate
Old Oct 4, 2004 | 10:03 PM
markk's Avatar
markk
look at it this way , if you dont get the valve timing spot on the you aint get the max powr out of your car - simple as !!
Old Oct 4, 2004 | 11:43 PM
xr4x4rs's Avatar
xr4x4rs
thankyou ppl will get sum oredered
Old Oct 4, 2004 | 11:45 PM
pugo's Avatar
pugo
make sure you get the ones with the markings on, as some come without and they are a pain in the butt!!!!!!
pugo
Old Oct 4, 2004 | 11:50 PM
djskitzy's Avatar
djskitzy
as above... they are a must with a posh cam
Old Oct 4, 2004 | 11:53 PM
xr4x4rs's Avatar
xr4x4rs
will do going to get the kent ones
thanx
SmudgerByName
52
Jul 28, 2016 06:14 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
mint_s2
Sep 2, 2015 08:58 AM
