zetec in mk3 escort, not sparking????Help.....
Old Sep 24, 2007 | 08:10 PM
ShandzS1's Avatar
ShandzS1
Default zetec in mk3 escort, not sparking????Help.....
Have just fitted the engine and tested for a spark, injectors aint pulsing either and no pulse at coilpack.Tried changing cps, coilpack, edis and plugs and still nothing....ignition and fuel pump relays are working. any ideas???
maybe one for safechav....
Old Sep 25, 2007 | 05:10 AM
Crank position sensor, have a look.
Old Sep 25, 2007 | 06:23 AM
JesseT's Avatar
JesseT
Check edis and coilpack for 12V when cranking.
Old Sep 25, 2007 | 09:51 PM
ShandzS1's Avatar
ShandzS1
Ive changed crank sensor, only 12v in middle pin on coilpack plug and 0v on outer pins when cranking. what pin on edis do i check for 12v when cranking???
Old Sep 26, 2007 | 06:53 PM
gup's Avatar
gup
what flywheel are you using fella is it the zetec one
Old Sep 26, 2007 | 09:42 PM
ShandzS1's Avatar
ShandzS1
yeah 105 bhp one
Old Sep 27, 2007 | 11:30 AM
ShandzS1's Avatar
ShandzS1
Could it be the ecu? ive checked the resistance of the cps when cranking and the ohm readings change.
Old Sep 27, 2007 | 01:29 PM
JesseT's Avatar
JesseT
No it can't really.
Old Sep 27, 2007 | 11:06 PM
ShandzS1's Avatar
ShandzS1
Wiring????? use the fault reader to find out whats wrong?
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
adriansaleem
Aug 1, 2015 09:28 PM
