S8 Ecu - Octane Wires????
Just a quick question, when I asked about the L8 the other say simon said about pins 13 and 14 being the octane wires.
I just wondered, is that still the same on an S8, and is it programmable what amount they take off, as I dont recall seeing it in the S8 software when I had mine.
Yes I am here, just got back from a very heavy corporate weekend dinner do. !
Sorry, the S8 doesnt support octane adjust in the same way.
However, you can load multiple maps into it (upto 8) and use inputs
to select them as you need.
When I say maps I mean complete configurations so you could load the
same file twice and just adjust the global ignition adjustment on one file,
That would then emulate what you need.
Very easy to set up
Very easy to set up
Ah, Ideal.
Porkie mentioned putting some Gas on his at some point, so was just checking the S8 can handle some retard if its needed
When you say "use inputs to select them as you need" will it do it on the fly?
Ie when the gas comes on it switches map?
You should, preferabley with a rusty spoon
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
