Mk5 fiesta with rear side lights not working
Old Sep 21, 2007 | 05:32 PM
Default Mk5 fiesta with rear side lights not working
Hi there my misses has a mk5 fiesta. Ive noticed that the rear side lights are not working. The front side lights are on and the rear number plate lights are on but not the rear side lights. Ive replaced the bulbs but still no different. Has anyone had the same fault . I will have to bring my tester home and check it out.
Old Oct 22, 2007 | 01:05 PM
Ken_ZS's Avatar
Ken_ZS
give the connections a good clean, it can only b somethin at the bulb as the fiestas wired lh rh rather than front to back so if the fronts r on the rears have power otherwise the fuse would have popped n the front would b off n number plate lights 2
Seanyfarrell
Aug 14, 2015 11:37 PM
CrOwSoN15
Aug 14, 2015 06:52 PM
turbobill
Aug 1, 2015 08:55 PM
