Escort Cosworth YBP crank size ??
Old Sep 20, 2007 | 06:54 PM
PAUL V's Avatar
PAUL V
Default Escort Cosworth YBP crank size ??
Has any one got any info on crank journal sizes for the Small Turbo YBP Engine ?
I have 2.04620" or 51.974mm for the big ends and 2.24250" or 56.959 for the main bearings, Would like to know top and bottum limits please
Old Sep 20, 2007 | 08:46 PM
PAUL V's Avatar
PAUL V
any one
Old Sep 20, 2007 | 08:52 PM
GUZZLER's Avatar
GUZZLER
if it helps, there the same as the big turbo.
Old Sep 21, 2007 | 07:26 PM
PAUL V's Avatar
PAUL V
Thanks I thought they were the same but would love to know what the size should be still
Old Sep 21, 2007 | 08:01 PM
Billabong's Avatar
Billabong
Main bearing journal diameter:
STD: 56.975 to 56.969
Undersize
0.25: 56.725 to 56.709
0.50: 56.475 to 56.459
0.75 56225 to 56.209
Big end bearing journal:
STD: 51.993 to 51.977
Undersize
0.25: 51.743 to 51.727
0.50: 51.493 to 51.477
0.75: 51.243 to 51.227
End float 0.1 to 0.254
All figures in MM from Workshop manual, for 4x4 engine (LT EsCos section says to refer to 4x4 figures).
Old Sep 21, 2007 | 08:25 PM
PAUL V's Avatar
PAUL V
Undersize
Undersize
Wonderfull Does it give clearance as the mains are 0.01mm under botum and i will plasigage it the check what clearance i have.
Thanks
Old Sep 21, 2007 | 09:51 PM
Billabong's Avatar
Billabong
Sorry mate, should have put that down too.
Clearance between main bearing journals and bearing shells is listed as:
0.025 to 0.079mm
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
