Actuator Fitting
Old Sep 19, 2007 | 09:43 PM
BlueFiesta85's Avatar
BlueFiesta85
Default Actuator Fitting
can someone just remind me which way the the actuator rod should be fitted, i.e should the the circle bit in the exhaust flange be in the closed or open position?
Old Sep 20, 2007 | 05:28 PM
Fiecos Dan's Avatar
Fiecos Dan
the actuator should be set with 4+mm preload, so needs pulling over the closed wastegate.
Old Sep 20, 2007 | 05:42 PM
BlueFiesta85
blackbeautyzetec
Aug 29, 2015 02:11 PM
jay030787
Aug 17, 2015 06:16 PM
