Big Brake Question.......
A quick question to anyone running big brakes on a s1/2 erst, Did you upgrade the master cylinder??
Heard using the mondeo v6 servo and cylinder is a popular upgrade??
Originally Posted by Christian and Beccy
Mine......
330mm AP's with Brembo 4-pots, standard 25mm Master Cylinder. No problems.
Originally Posted by tont2002
they look sweet, also same wheels ive just bought, did you any issues fitting the brakes behind them?????
Whats the pedal feel like mate???
Cheers m8y
Cheers m8y
Pedal feel is OK. Not perfect, but I think that's got more to do with other inadequacies in the system.
My brake system has been entirely repiped too, more conventionally, with a Bias valve in it too.
7x16" with 195/45/16's when I did the conversion, although I now have 205/45/16's.
Caliper clearance to the inner face of the wheel is OK, but it's the diameter of the whole brake set-up that is the problem. 16's just aren't really big enough. My wheels are ruined on the inside, where stones get caught between the caliper and the wheel!!
