Does escort diesel van gearbox fit in s2 rst????
Old Sep 11, 2007 | 06:26 PM
zsdave's Avatar
zsdave
Default Does escort diesel van gearbox fit in s2 rst????
Just bought my first rs turbo and it crunches into second. ive been told a cheap alternative would be to fit a escort diesel van gearbox. Does it go in perfect or is it a bit of a boj job?
Old Sep 11, 2007 | 06:34 PM
Moonie's Avatar
Moonie
It will be a direct replacement however you wont have a limited slip diff and the gear ratio's will be incorrect
Old Sep 11, 2007 | 07:02 PM
kiddie's Avatar
kiddie
I ran one for a few months in my 1st RS. Even with no LSD never had any problems only in the wet.
Old Sep 11, 2007 | 07:31 PM
zsdave's Avatar
zsdave
Thanks for the replys, is there any specific year that the box has to come from?
cheers
Old Sep 11, 2007 | 07:38 PM
kiddie's Avatar
kiddie
no mate any mk4
Old Sep 11, 2007 | 11:02 PM
Grandad racer's Avatar
Grandad racer
mines got a dieasl box on at the mo,ok so no lsd, but the ratios are wider!,you can hold the gears longer, wicked!!
Old Sep 11, 2007 | 11:09 PM
smitsturbo's Avatar
smitsturbo
why not just spent £100 on a propper rs box with an lsd, the deisel box isnt any stronger???
Old Sep 12, 2007 | 08:02 AM
JesseT's Avatar
JesseT
The myth of the escort van gearbox started from the knowledge or legend that some of them had a LSD fitted from new.
Old Sep 12, 2007 | 03:35 PM
Oranoco's Avatar
Oranoco
Yes it will fit but it's a complete bodge and you'll be left with a gearbox that's no tougher, has no LSD and has crap ratios for the car. Generally about as good an idea as dangling your goolies in a pirhana tank at feeding time.
Spend once and spend right get yourself a proper rebuilt RST unit
Billy_RS
16
Oct 11, 2025 09:41 PM
A.t.p
Aug 15, 2015 11:37 AM
RsS2daz
Aug 14, 2015 05:26 AM
dlwarrior
Aug 5, 2015 10:19 AM
