bloody 3dr brakes
Old Sep 10, 2007 | 07:07 PM
3doorcozmess's Avatar
3doorcozmess
Default bloody 3dr brakes
Im having problems with my brakes on my 3 door was driving the other day and they stopped working,
Just went to my car to have a little play, turned ignition on and the abs pump buzzed as normal and they worked again drove for about 15 mins then give the ant lag a blip as u do and when turned it off about 2 mins later no brakes, coincidence I thought but I don’t know, I touched the bottle and wire that runs to the abs and it was hot and soft not sure if that’s normal or coursing a problem as got different heat shield
Any ideas has anyone had same problem
Many thanks
Old Sep 11, 2007 | 01:43 PM
The pump motor could be on the way out, aided by extra heat if fitted with no effective sheiled ?
Old Sep 11, 2007 | 03:21 PM
3doorcozmess
ok mate cheers
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
