Escort Cosworth - Diff ratios HELP!!
Old Sep 10, 2007 | 01:25 AM
bennydg's Avatar
bennydg
Default Escort Cosworth - Diff ratios HELP!!
We are currently running an Escort in Tarmac events and are currently changing diffs to 3.6:1 in the front (basically standard ratio) and 4.1:1 in the rear. We have new gears and morse chain for the transfer box to get a 1:1.148 ratio between front and rear but the ratio between the two diffs is 1:1.138. Obviously this small mismatch will cause the viscous centre work a bit. Does anyone know whether this amount of "slip" in the viscous is a problem, it seems to me it only a bit over 1% so should be ok but some knowledge would be good.
Old Sep 10, 2007 | 10:39 AM
ian sibbert's Avatar
ian sibbert
Have a read of this thread and perhaps talk to bernie @cts
https://passionford.com/forum/viewto...asc&highlight=
I would say it wont make any difference...and you'll be fine pal
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
