Wanted: Power steering supply hose - 4x4 sapph cossie
Hi all,
I need the hose that goes from the power steering pump to the rack (supply), not the one that goes from the rack back to the fluid reservoir.
For a J plate sierra sapphire cosworth 4x4.
Note, it has v-belts like the 2wd, not the wide belt as found on more recent cars. The power steering pump is on the right hand side of the engine bay (inlet side of engine), not on the right as I believe is the case on some J/K cars.
Thanks
Greg
Thanks
Greg
Karl 3dr
102
Oct 14, 2016 08:17 PM
