cossie brakes upgrade
Old Aug 30, 2007 | 05:58 PM
raycov's Avatar
raycov
Default cossie brakes upgrade
i went to fit them this afternoon,283 cossie 2wd dics,4wd calipers,4wd pads.everthing went according to plan till i tried to put the caliper on ,what a f game they dont go over disc. i had some old pads with some meat on them and they slid over no problem,so the problem is the pads,they are 4wd drive red dot from burtons to match the discs what do y ou reckon lads
Old Aug 30, 2007 | 06:00 PM
antony215's Avatar
antony215
Escort Rs Turbo
I take it you pushed the piston right back???
Old Aug 30, 2007 | 07:06 PM
raycov's Avatar
raycov
yes. theres to much meat on the new pads so it seems
Old Aug 30, 2007 | 07:07 PM
GraphiteGray's Avatar
GraphiteGray
Did you put 1mm spacer washers between the hub and the caliper?
Old Aug 30, 2007 | 07:23 PM
raycov's Avatar
raycov
yes
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
