Kenwood stereo, sub, amps, speakers, jbl subs and amp
I have for sale some stereo stuff what came out of my last car and what is going to come out of my latest car
Kenwood KDC-W8027 £110
Comes boxed with remote, cage, wiring, instructions etc
http://i14.ebayimg.com/07/i/000/b1/ed/ad45_12.JPG
KDC-W8027 main features:
Compatible with MP3 and WMA format discs as well as conventional audio CDs
FP-MASK two stage motorized front panel
MASK-KEY security system via removable section of front panel
Eight tone 3D fluorescent fine-pitch, full-dot display with dimmer
Three step display and four step control panel angle adjustment
Rotary volume control. Red or green (switchable) button illumination
Radio can be connected to factory-fitted remote controls and external dashboard displays on most cars (adaptor required)
Compatible with current model Kenwood CD / MP3 changers
Accepts RCA auxiliary inputs to connect iPod, walkman etc.
Infra-red remote controller included
CD-R / CD-RW compatible
Display of CD text information from head unit or compatible CD changer. Display scrolls if necessary
Disc Name Preset allows names to be assigned to discs in optional CD changer. When disc is selected the name will appear on the radio's display
Disc Name Preset Play allows you to select by name any disc in optional CD changer. (Optional hand-held remote control is required)
RDS (radio data system) & EON (extended other networks) tuner
DAB tuner can be added as an option for Digital Audio Broadcasting reception
Full coverage of LW / MW / FM wavebands
Display of radio text information
4 x 50 Watts max power (MOSFET)
System Q-EX sound control
System E+ provides high-pass filter and bass boost with phase inversion for improved bass frequencies. Front and rear speakers can be individually adjusted
BMS external amplifier control
Analogue SRS WOW system for surround sound experience
Internal amplifier disable option
0-bit muting for silence between tracks
Switchable dual-zone allows playing different sources to front and rear speakers simultaneously
Three RCA preouts (2.0 volt) for connecting external amplifier
Display auto-dims when vehicle's side lights turned on
24 hour clock display
Two way telephone mute
Automatic turn off (after selectable delay
Kenwood 10 disc cd changer, with lead, very good condition £45
Kenwood 10" sub in carpeted box £30
Kenwood amp was fitted to run the above sub sounds really good £25
Kenwood amp was fitted to Kenwood 6x9's below £25
Kenwood 6x9 speakers with grills £20
JBL GTO 400 watt amp £40
JBL 10" 1000w sub in carpeted box £25
JBL 10" 1000w sub not in box £20
any questions pls pm me!!
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
