cossie brakes problem...
Old Aug 26, 2007 | 06:26 PM
Mixja's Avatar
Mixja
Default cossie brakes problem...
hello all
have just fitted cossie 4x4 calipers n 2wd front disks to the s2, but for some reason tho, the edge of the disk is fouling the inside of the caliper...
having a couple of mm machined off the dge of the disk but was wondering if anyone else has had this problem, ive never seen a thread about it tho!!!
thanks!!
Old Aug 26, 2007 | 06:28 PM
dave_y's Avatar
dave_y
you need to space the calipers out with a 1mm spacer
check out the sticky at the top of this forum.
Old Aug 26, 2007 | 07:19 PM
project rs's Avatar
project rs
i just took the excess of the caliper only needed a quick sand to make it clear and saves you getting the discs done every time
Old Aug 26, 2007 | 08:20 PM
dave_y's Avatar
dave_y
ah right, re-read your post ignore what i said earlier!
make sure the calipers are clean as most have 1-2mm of shite on them(dirt etc)
Old Aug 27, 2007 | 12:13 AM
Mixja's Avatar
Mixja
well, theyve just been done by big redd, theyre clean as!!
caliper is just too close to the edge of the disk...
jeez, nowt's ever easy is it..??!!!
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
