YB & Cossie Parts......LOADS...All must go soon
Rubber Rhino Crew
OFFERS ON EVERYTHING, REASONABLE OFFERS NOT TURNED DOWN I JUST NEED IT ALL GONE TO GET MY FIESTA PROJECT IN THE GARAGE NOW AND ALL THIS JUNK TAKING UP ROOM
SEND ALL OFFERS VIA PM TO KEEP THIS THREAD ORGANISED..
YB and sierra bits in green
Koni Adjustable rear dampers
Organic fast road AP clutch plate....came as part of a kit on my engine but i'm keeping cover and using 6-paddle with it....only 500 miles old and has plent of meat left..barely worn in (i can measure thickness if req'd)
Std 4x4 cossie blue injectors (all working when removed from car)
ABS pump and block..all brake lines connecting pump to block,
std 4x4 actuator and std cossie fuel pump both GWO
5x 17inch MOMO alloy wheels with centre caps...can be seen in these pics
4 wheels currently in silver 1 in black...one silver has scuff mark but easily sorted and the black one I had refurbed after a dink to black (looks better in black imo) also will throw in spacers for back if req'd
4x avon zz1 tyres 205 45 17's (I think not 100% sure on number will clarify if interest..theyre in the roof
) all very good tread 6-8mm over the 44x4 cossie loom needs a few metal clips on some of the 2 pin connectors but nothing major, all worked fine when removed from car...just I lost 1 or 2 of the metal clips removing the loom.
2x sets of ht leads, nothing special but work fine
Sub and amp, sony xplod 700w sub and JBL gto amp 800w, scruffy box but all works fine...comes with wiring
Sony 10CD changer with cd cartridge, bus lead and audio lead...also steering colum controls
Secs S8 ECU, latest software update to allow ALS etc comes with lead to connect to pc/lappy... not sure if it can do 6cyl engines might be a possibilty to use on 24v conversion?? if not as a spare or anyone doing a cossy management on rst etc... SWAPPED FOR P8
PAIR Willans 4 point harnesses (although the buckle can take a bollock strap and become a 5 point) in black SOLD
Strut brace SOLD
hoses SOLD
Gearbox SOLD
24V PARTS SOLD..DEPOSIT TAKEN (to xr4x4x24)
24vcosworth Turbo cams (piper grinds) never fitted after grind, come with a set of decent tested hydraulic lifters and pulleys
24v Low comp pistons (machined original items) with rods
24v Brand New crank with full set of new bearings
24v 2wd sump and pickup pipe
24v 4x4 sump and pickup with turbo and head oil return pipes welded in
24v Plenum & TB
24v 8mm thk port profiles for making turbo headers (plasma cut by my mate) out of mils steel plate
24v bottom end...seen better days, done arround 80k and was only removed when timing chain tensioner slacked and caused valve to bend...obviously comes with everything a second hand short motor would...i.e pistons (normal comp ratio), crank, oil pump etc..
Various other 24v parts that I must have missed off the list...but b asically if you brought a bruk down old 24v granada you'd have all the bits to do a decent turbo conversion... with 2xt3's its possible to see 600bhp (fitz's blue 3rd made this this with 2xt3 (4x4 cossie trim) turbos..albeit with a different plenum.
ALL ITEMS LOCATED IN BIRMINGHAM SUTTON COLDFIELD AREA (B24 postcode) JUST OFF M6 OR A38 ETC...
ITEMS CAN BE COLLECTED IN EVENINGS OR WEEKENDS OR CAN BE POSTED AT ADDITIONAL COST
PAYPAL/BANKERS DRAFT OR BANK X-FER ONLY ON ITEMS REQUIRING DELIVERY
Rubber Rhino Crew
hi mate how much for the harness please
is there a pair of harnesses????
nice one mate for the box, fitted when i got home just got a couple of bits to finish off and hopefully back on the road, cheers for all ya help mate much appreciated
you must have been up late last night fitting that!!!!! you didnt leave mine till gone 9..30 and its an hours drive :S LOL anyhow good luck with the rest of the car!Dan
Rubber Rhino Crew
Originally Posted by dangerbrian
did you receive my payment for the loom
Dan
Rubber Rhino Crew
Glad your happy mate! Just remember to keep the cams and crank oiled up! sealed in a bag and put them somewhere they wont rust! I had a cam in my old garage I thought was mint but over time I didnt oil it and it was rusted to f*ck when I needed it
Nice meeting you mate...top dude
Dan
Dan
Russ Payne
Sep 25, 2015 08:29 PM
offers on everything as I just need it all gone....Reasonable offers not turned down.
