Stereo Wiring for 1990 XR2i
Old Aug 6, 2007 | 09:39 AM
zowow's Avatar
zowow
Default Stereo Wiring for 1990 XR2i
I bought the worlds worst shed of an XR2i as a runaround, but I just wanted to know, speakers are easy but its the power that I can't quite work out.
1x thick brown wire
1x thin brown wire
1x thin red wire
1x thin yellow wire
I know i will need an illumination, live, switched live and earth, but which is what? Canne be arsed to borrow/buy a multimeter, so if you can tell me i'd be more than pleased
car is awful by the way, rust on every panel! goes ok though
Old Aug 6, 2007 | 10:28 AM
Brown is earth.
THIN red/yellow, one is ignition switched live, the other is permanent live for the radio memory, sorry can't remember which is which, so just probe them both till you see which is which.
Old Aug 6, 2007 | 10:32 AM
zowow's Avatar
zowow
hmm, i'll give it a go, but theres the other wire as well ?
Old Aug 22, 2007 | 09:17 PM
tonto's Avatar
tonto
Thick brown is earth/chassis neg
Red is permanant battery live
Yellow is position 2 on the key switch/accesory live
Hope this helps.
Tonto
mark94
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
