New Collins pro ecu monitor
Old Jul 30, 2007 | 04:11 PM
Mark_w's Avatar
Mark_w
Default New Collins pro ecu monitor
New Collins Performance Engineering Engine Monitor.
This works with all RS Cosworth managed ECU magneti Marelli L6, L8 or P8 ECU. Easy to install - plugs into ECU diagnostic connector but check for your application as it will not work with my chip on l6 ecu,you need a collins chip with l6 or convert to l600 or have L8 or P8.
Main features
Displays real time engine information; Engine RPM, Coolant Temperature, Charge Air Temperature, Boost Pressure, Battery Voltage, Throttle Postion, Ignition Timing, Fuel Injector Opening Time, Sensor Fault Detection, 4 Channels of Analogue Data (Lambda) Current Ignition Map Address, Current Fuel Map Address, Blanket Fuel Adjustment, Blanket Ignition Adjustment.
COMES WITH ALL INSTRUCTIONS & MANUAL
These are £470 new, I am looking for £325
regards mark
Old Jul 30, 2007 | 04:19 PM
AndyRS's Avatar
AndyRS
PM sent
Old Jul 30, 2007 | 04:20 PM
Mark_w's Avatar
Mark_w
Originally Posted by AndyRS
PM sent
replied
regards mark
Old Jul 30, 2007 | 04:51 PM
Mark_w's Avatar
Mark_w
sold
regards mark
Old Jul 30, 2007 | 05:07 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
9 mins
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
