GT25/40R turbocharger on sierra 2wd cosworth motor
I would like to get advices from people who have experience on turbochargers. I have got gt2876r (gt25/40r) dual ball bearing turbocharger with a/r 0.82. I would like to know, When I can expect to see full boost (20-22psi)? Will it be very laggy? How much boost i will have to push, to see such power? The car is for everyday use, and I want to reach 370bhp limit. Motor is fully standart. 3" straight exhaust, rs500 IC with 70mm tubing, 3bar map sensor, grey injectors (i also have light blue ones).. Please give me advices. thanks.
hi
i am running this turbo on my 2.0L zvh fiesta with a 0.64 housing very good spool positive boost by 2100 full boost by 3300 yours wont spool up as well with the 0.82...
sean
sean
but your motor is highly modified, also manifodls, cams etc.. so thats why you have such a good spool up time. :S maybe can others help me and try to count what i cna ahve on mainly stock YB engine. Thanks
charliecosworth
Aug 19, 2015 02:00 PM
155lee
Aug 14, 2015 11:21 AM
