FAO Turbo expert types- Removing silencer ring C-clip?
Old Jul 27, 2007 | 07:32 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default FAO Turbo expert types- Removing silencer ring C-clip?
Ie FAO Carl, Danny, someone who takes turbos to bits...
How do you remove the C-Clips that secure the silencer ring on the front of some ported shroud inlet turbos?
It sits in a groove on the inlet, securing the silencer ring in place, and i cant prise the fucker out with a flat blade screwdriver, and barring that im all outa ideas?!
Cheers in advance
Old Jul 27, 2007 | 07:35 PM
Rick's Avatar
Rick
You need to give the screwdriver a good crack - you are then supposed to replace the circlip with a new one.
Old Jul 27, 2007 | 07:36 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
pretty much yeah, but there nowt to grab hold of, just the one side of the gap is angled a little, meaning you can exert force on that with a screwdriver etc, but the screwdriver slips before i can compress the clip.
Old Jul 27, 2007 | 07:37 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
why would i need to replace it? it will do nothing if the silencer ring is not there, if anything it would rattle around loose in the groove
Old Jul 27, 2007 | 07:39 PM
Rick's Avatar
Rick
It's just std practice But i'm sure u can decide for yourself how critical it is
Old Jul 27, 2007 | 07:41 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
what are circlip pliers?
this isnt a clip with them little holes either end you can get something in to compress it etc, tihs is just a circle of metal with a lil bit chopped out of it
Old Jul 27, 2007 | 07:51 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Ahh, see, i have no idea what was a normal one
When you said that I googled it and it shown that type and this type
Heres a pic to explain my problem, and also note the c-clip sits in a groove so cant just prise it outwards, and im fooked it i can compress itby pressing a screwdriver on the angled bit...
Old Jul 27, 2007 | 08:19 PM
Billabong's Avatar
Billabong
Are you using one or two (one to hold it, one to pop it), small flat bladed screwdrivers?
Old Jul 27, 2007 | 08:22 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
one, as only one side of the clip is at a suitable angle to get any type of grip on it
Old Jul 27, 2007 | 08:25 PM
Billabong's Avatar
Billabong
You have a PM, dunno if it'll help or pi$$ you off
Old Jul 27, 2007 | 08:27 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
well ive not read the PM, but just found this!
http://www.dodgeram.org/tech/dsl/FAQ/Inletnew.pdf
Old Jul 27, 2007 | 09:29 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Done it! Not quite how they all describe though, its just too strong to physically do that.
But you could just about jam one in at an angle to force it away a bit and get another underneath to prize it out.
Job done, i now have a far noisier turbo
Old Jul 27, 2007 | 10:12 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i was gonna say, use one screwy to lift the ring, then another to work around with
but you done it, so i wont bother
Old Jul 27, 2007 | 10:52 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
it wasnt quite that mate, it was the fact the obvious way to lift it didnt work
a way i expected to be a lot more likely to slip worked, just as it gave more leverage, job done
now i just got to work out how big the turbo is not sure, need a GT35 or 40 to compare it to really.
looks awesome tho, and as it that "small" i can use it on my chaser
Matt Baxter
Sep 16, 2015 08:30 PM
KW-rscos
11
Aug 31, 2015 01:51 PM
Aug 29, 2015 08:16 PM
kevin36
Aug 14, 2015 08:36 AM
