TO MUCH PRESSURE????
Can you run to much OIL pressure,
my brother's mk3 RS Turbo as just let go whilst on it's first run.
The turbo was bought brand new about 3 years ago from Turbo technics and is there stage 3 version, tonight was it's first real ride out as after 5 long years he's finished his rebuild.
Now the Turbo as only done 27 miles, yes 27 and just spat oil all over the bay, he as fitted an up rated oil pump and from cold idle the pressure is about 75psi and on warm idle it's on 20 psi and when rev'd at 2000 rpm cold is 80 psi and warm is 40 psi, is this to much pressure or is there an issue with the turbo, although after 3 years warranty means nowt
Originally Posted by JTECHSAFF
i had too much oil pressure when i had a faulty cosworth oil pump and it burst the oil filter
and it fucked the big ends.
car didnt even start, that was just turning it over!
mine was ruunig fine ,i drove it around the block came back for a little check over ,opened the bonnet and gave it a little rev and i could see the oil filter changing shape then BANG oil everywhere....including in my face...and it was hot
ta boss,
i'm now nicking yor sig, lol
when it happened to me id never heard of ANYONE it happening to before. maybe we should start a club
mine was i dunno, 2001 maybe? fresh rebuild in the 3door, think i may have still been running it in. went to start it but it just turned over, didnt start.
got out to check under the bonnet and the oil filter had blew and was oil everywhere.
presuming it was a faulty filter i went n got a new one and a load more oil and it did it again!
then once engine out n checked it had caned my brand new fucking bearings
i was told to "strap the oil filter"
what did cosworth say?
they gave me a new pump
great ,what about a new face ,cleaning all the mess ,taking the engine out to fit the new one
i cant even remember, some lame excuse i think
cheers lads, your excuse really comforts me in this time of extreme wallet raping
And Jeremy said a couple of years ago they had a batch of 100 made,
20 of which were faulty as had no hole drilled in the relief valve, so over pressured.
But only 5 had been sold before it was noticed, of which only 2 had been fitted and run up.
sounds almost too much, so yeah, deffo fine.
and basically, like most cars, if they all fairly equal across all 4, you know its healthy enough.
its not cyl pressures thats a problem on S13, its fucked big ends.
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
