Electric sunroof query
there you go m8, I fitted a leccy motor to my old saph, if the cog on the motor has too many teeth then get a granada one and swop the cog over, this then fits straight on, unless you got the motor off a granada in the first place!
steve
*edit* can't work out why the pics won't show
but you need a sierra mechanism as it sits lower into the cowling than the granada one
you've got coarse and fine splines, but the biggest problem is getting the bracket from the doner car as loads of people forget and then can't ge another one (2 of the bolts come in from the top downwanrds)
